How Does Kinetic Friction Affect Block Acceleration?
The discussion focuses on calculating the acceleration of a block affected by kinetic friction when a force is applied at an angle. For part a, the acceleration is derived as a function of the applied force P, resulting in the equation a = 4165.001 + 0.001P. In part b, specific values for P (11.13 N and 22.26 N) are used to find the corresponding accelerations and frictional forces, with calculations yielding an acceleration of 14.206 m/s² for P = 11.13 N. Part c addresses determining the minimum acceleration when the block is on the verge of motion, suggesting the use of calculus for optimization. Overall, the thread seeks validation of the calculations and methodology used in solving the problem.
chocolatelover
A 425 g block is at rest on a horizontal surface. The coefficient of static friction between the block and the surface is .770, and the coefficient of kinetic friction is .220. A force of magnitude P pushes the block forward and downward. Assume the force is aplied at an angle of 40°
a. Assuming P is large enought to made the block move, find the acceleration of the block as a function of P (Use P as necessary and round numbers to the third decimal place)
b. If P=11.13 N and then P=22.26, find the accelerations and the frictional forces exerted on the block
c. What is the minimum acceleration for the block when P is a minimum and motion is just ready to begin?
a. ΣFx=Pcosθ -f=ma
ΣFxy=N-mg-Psinθ=0
f=μN
Pcosθ-μΝ=ma
Pcosθ-μ(mg+sinθ)=ma
(cosθ/m)P-mg+(μsinθ/m)P
-mg+μsinθ/m +(cosθ/m)P=a
(-425g)(9.8m/s^2)+(.220sin40/425g)+(cos40/424)P=a
a=4165.001+.001P
b. P=11.13
a=4165.001+.001(11.13N)
4165.012
f=μΝ
N=(4165.012)(11.13)+425g(9.8m/s^2)
c. For part c. I was thinking about using Calculus to minimize the equation, would that work?
Could someone please tell me if this is correct so far and if it isn't could you please show me what to do?
Thank you very much
Could someone please tell me if this looks correct?
a.
μs=.770
μk=.220
ΣFx=max
ΣFx=Pcos40-f
f=μkN
may=0
0=Σfy=N-mg-Py
=N-mg-Psin40
=Pcos40-[.220(mg+Psin40)]
ΣFx=max
Pcos40-.220(mg+psin40)=max
pcos40/.425kg-.220(.425(9.8)+psin40)/.425=ax
1.47p-2.155=ax
b.P=11.13N
1.47(11.13N)-2.155=ax
ax=14.206m/s^2
f=μkN
=.220(9.8m/s^2)
f=2.156
c. I would then do the same thing for part c, right?
Thank you very much
