How Much Energy Is Lost to Friction in a Spool of Wire System?
The discussion focuses on calculating the energy lost to friction in a spool of wire system, specifically involving a spool with an inner radius of 0.40 m, an outer radius of 0.55 m, and a moment of inertia of 0.7139 kg*m². A mass of 1.350 kg pulls the wire down a distance of 0.550 m, resulting in a final speed of 0.654 m/s. The key conclusion is that to determine energy loss due to friction, one must consider the change in potential energy and the kinetic energy of the system.
  • Understanding of potential energy and kinetic energy concepts
  • Familiarity with rotational dynamics and moment of inertia
  • Basic knowledge of energy conservation principles
  • Ability to perform calculations involving mass, distance, and speed
  • Calculate the change in potential energy using the formula PE = M * g * D
  • Determine the kinetic energy of the mass using KE = 0.5 * M * v²
  • Analyze the energy balance to find the energy lost to friction
  • Explore the effects of varying the radius and mass on energy loss in similar systems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for practical examples of energy loss in rotational systems.
dana711
A spool of thin wire (with inner radius r = 0.40 m, outer radius R = 0.55 m, and moment of inertia I_cm = 0.7139 kg*m^2) pivots on a shaft. The wire is pulled down by a mass M = 1.350 kg. After falling a distance D = 0.550 m, starting from rest, the mass has a speed of v = 65.4 cm/s. Calculate the energy lost to friction during that time.
im not really sure how to do this. i would like any ideas.
Consider the change in potential energy.
  • · Replies 19 ·
  • · Replies 42 ·
