Thread Closed
Finding the direction of the resultant vector of three vectors?
Share Thread Thread Tools
Mar29-08, 09:49 PM   #1
Hi,
I was wondering how one would go about finding the direction of the resultant of three vectors, when performing a vector addition of three vectors. I mean I know how to find the magnitude, by summing all the squares of the component vectors, i and j, and square rooting that sum, but how does one get the direction of that third vector? The whole thing forms a polygon, for god's sake.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Mar29-08, 09:56 PM   #2
Have you heard of the "Tip to tail method"?
Mar29-08, 09:58 PM   #3
yeah, the only problem is finding the exact direction in degrees using that method is questionable.
Mar29-08, 09:59 PM   #4
For this specific problem I have a motorist drives south at 20.0 m/s for 3.00 min, then turns west and travels at 25 m/s for 2 min, and finally travels northwest at 30. 0 m/s for 1 min. the respective position vectors are -3000 to the west (negative x-axis), -3000 to the south (negative y-axis), and 1800 to the northwest, 45 degrees from the x/y-axes.
Mar29-08, 10:05 PM   #5
Split it into your x and y components. Use your trigonometric funtions to find the direction and use the pythagorean theorem to find the magnitude.
Mar29-08, 10:09 PM   #6
whaaaaaat, that was last week man. These are three main vectors I computed. I already found the magnitude. I just can't find the direction now of these three. The components of the 1800 NW vector you mean? Tail to tip method says -nothing- about components., you have to use your main resultant vectors (the three here) to find the full resultant vector.
Mar29-08, 10:10 PM   #7
Point is, now if i use the tail-tip method, I have a polygon
Mar29-08, 10:15 PM   #8
So, you do want to do it graphically? You can do it both ways. If you are instructed to do it algebraically, do it the way I said. If you are instructed to do it graphically, use tip to tail. If given no specific method, use whichever is more comfortable for you.
It doesn't matter if you have a polygon; You don't have to make a triangle with the vectors. It will still work. If you don't believe me, add two of the vectors and then add that vector to the third.
Mar29-08, 10:19 PM   #9
Alright; I'd much prefer algebraically. Can you outline how I find the direction of the resultant vector of three vectors?
Mar29-08, 10:28 PM   #10
Draw a picture. Two of your vectors should be incredibly easy to break into components since they are due south and due west. You will need to use trig functions to break the other into components(hence the drawing to determine which functions).
Add the components so you have a resultant x component and a resultant y component. To find the magnitude, use the Pythagorean theorem. To find the direction, use the trig functions(again, use the picture).
Mar29-08, 10:36 PM   #11
Dude, listen I did all that. they are incredibly easy to break down into components BECAUSE THEY ARE COMPONENT VECTORS, it's -3000j and -3000i the third vector can be broken down using sin and cosine. MY FIRST POST talked about doing it graphically and that the problem is i didn't know if I SHOULD EYEBALL the direction angle or what. All I'm asking is for an outline of how i should go about discovering the angles exactly, whether it be algebraically or tail to tip.
The 2 resultant angles are 45 degrees. FINE. getting the angles of the resultant of THESE two are my question.
thanks.
Thread Closed
Thread Tools
Similar Threads for: Finding the direction of the resultant vector of three vectors?
Thread Forum Replies
resultant force direction Introductory Physics Homework 3
Need help w/ arranging resultant vector with 3 other vectors. D: Introductory Physics Homework 3
Vectors (Direction of Resultant Displacement) Introductory Physics Homework 3
What is the correct method of finding the direction of a Vector Introductory Physics Homework 5
Finding the direction vector with only direction angles.. Calculus & Beyond Homework 1
