For which value of x horizontal Tangent Line
chaosblack
For which value of x...horizontal Tangent Line
For which value of x does f(x) = \frac{k}{ax^{2}+bx+c} have a horizontal tangent line?
Quotient Rule?
F'(x) = [g(x)a'(x) - a(x)g'(x)]/g(x)^2?
Am I supposed to just sub it into a quotient rule format, making the derivative equal to 0?
So it would look like
0 = 0 - (2ax + b)/[[ax^{2}+bx+c]^{2}]? (and then simplify of course?)
That's correct. But there are certain restrictions on the values of a, b, and c.
(Also, when there is only a constant in the numerator, like f(x) = k/g(x), then you can directly use f'(x) = k d/dx[1/(g(x)] = k[-g'(x)/[g(x)^2], which is nothing but the quotient rule in a lesser number of steps.)
okay thanks, so the answer would just be the derivative set equal to 0?
yes it is
okay thanks alot
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
