Is Building a Radio Transmitter for Wireless Earphones a Feasible Solution?
  • Thread starter Thread starter daniel_i_l
    Building Wireless
Building a radio transmitter for wireless earphones is proposed as a cost-effective alternative to expensive Bluetooth options for MP3 players. The idea involves creating a transmitter that plugs into the MP3 player and transmits music over a short AM frequency to a custom receiver connected to earphones. Concerns are raised about maintaining sound quality with this method. An alternative suggestion includes using FM radio headphones paired with an FM modulator, which could be a more straightforward and affordable solution. Overall, while the DIY transmitter idea is interesting, there are simpler options available that may achieve the desired outcome without compromising sound quality.
daniel_i_l
I wanted to get wireless (bluetooth) earphones for my mp3 player but when I checked I found that they were way out of my price range (bluetooth earphones for phones with bluetooth are relatively cheep, but for a regular mp3 player they're expensive ~ 200 dollars).
So I had an idea: I can make a radio transmitter that plugs into where my earphones normally plug in and make it transmit the music at some AM frequency up to about a meter - and then make a tiny radio receiver for that frequency only which I connect to some earphones. The I just have to plug the transmitter into the mp3 and the music will be transmitted to the earphones.
Now, I've never actually built a transmitter before (just the receiver) though I'm pretty sure I know how. So my question is - do you think that this is a feasible solution to the problem? Would it be possible to build a transmitter that didn't substantially lower the sound quality? Are there better solutions to this problem?
Thanks.
How about some fm radio headphones and a fm modulator like they sell for playing mp3's in your car. It would all be < $50 I would think.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
