Moment of Inertia of Wire Shaped like Astroid: Finding MOE | Solution Attempt
  • Thread starter Thread starter kasse
    Intertia Moment
The discussion focuses on calculating the moment of inertia (MOI) of a wire shaped like an astroid defined by the parametric equations x=cos³(t) and y=sin³(t) for t in the interval [0, 2π]. The initial attempt to find the MOI involved integrating k*(x² + y²)ds along the curve, leading to an incorrect result due to a mistake in the expression for ds. The correct formulation for ds is 3|cos(t)sin(t)|dt, which accounts for the absolute value, ensuring that contributions do not cancel out when integrating over the full period.
  • Understanding of parametric equations and their derivatives
  • Knowledge of moment of inertia concepts in physics
  • Familiarity with integration techniques, particularly for periodic functions
  • Experience with calculus, specifically dealing with absolute values in integrals
  • Review the derivation of moment of inertia for complex shapes
  • Study the properties of periodic functions and their integrals
  • Learn about parametric integration techniques in calculus
  • Explore the application of absolute values in integrals to avoid cancellation errors
Students studying physics or engineering, particularly those focusing on mechanics and calculus, as well as educators looking for examples of integrating parametric curves.
kasse
A wire is shaped like the astroid x=cos3(t), y=sin3(t), t[0, 2*pi] and has constant density = k. Find its moment of intertia I0 around the origin.
2. The attempt at a solution
To find the MOE we must integrate k* (x2 + y2)ds along the curve. We differentiate and find that ds can be written 3*cos(t)*sin(t).The final expression is:
3k * Int (cos7(t)*sin(t) + sin7(t)*cos(t))dt for t [0, 2*pi]. But this is zero! What/where is my mistake?
Be careful when integrating periodically symmetric functions through a full period: your dt cycles through both positive and negative signs. You may be better off integrating only one quarter of the astroid and quadrupling that result. (Were you to express the moment of inertia as C · M · (R^2) , the moment for each quadrant would have the same constant C as the entire figure.)
Your mistake is: changing the function for ds when doing your simplification!
[tex] ds = \sqrt{\left(\frac{dx}{dt}\right)^2+\left(\frac{dy}{dt}\right)^2} \;dt<br /> = 3\sqrt{\cos^2(t)\sin^2(t)}\; dt \;\neq \;3 \cos(t)\sin(t) \;dt[/tex]
[tex] 3\sqrt{\cos^2(t)\sin^2(t)}\; dt = 3|\cos(t)\sin(t)|\;dt[/tex]
that's why you have the two contributions cancelling each other out... you have forgotten the absolute value sign...
  • · Replies 22 ·
