Finite Differences & Leading Coefficients Relation
The discussion focuses on understanding the relationship between the nth finite difference of a polynomial and its leading coefficient. It is suggested to start by analyzing simple polynomial cases to observe patterns in their finite differences. The initial thought is that the sign of the nth finite difference corresponds to the sign of the leading coefficient. Participants are encouraged to explore specific examples, such as the first difference of a linear polynomial and higher-order differences for quadratic and cubic polynomials. This approach aims to clarify the concept and guide towards a solution.
dvmckay23
Determine the relation that exists between the nth finite difference and the leading coefficient.
... I'm not too sure how to html it up properly, but the numbers/"n"s following the "a"s are meant to be sub-script:
f(x) = anx^n + an-1x^n-1 + ... + a2x^2 + a1x + a0
If someone could even tell me the proper direction for the line of thought here. All I can figure out thus far is that the difference is the same sign (positive or negative) of the coefficient. Any hints would be GREATLY appreciated!
Thanks!
~D
Are you assuming an nth degree polynomial?
Try some easy cases first. What is the first difference of ax+ b?
What is the second difference of ax^2+ bx+ c?
What is the third difference of ax^3+ bx^2+ cx+ d?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
