Register to reply
Two Vectors define 2D space
by winston2020
Tags: define, space, vectors
Share this thread:
winston2020
#1
May18-08, 04:28 PM
P: 35
Question: Determine whether the following sets of vectors form bases for two-dimensional space. If a set forms a basis, determine the coordinates of V = (8, 7) relative to this base.
a) V1 = (1, 2), V2 = (3, 5).
On the first part of the question, I'm a little foggy on how I go about doing it.. I think I have to figure out if they're collinear right? And if they're not, then they can be used to define any other vector in two-dimensional space... is that right?
And so, if that's the case (I believe that they are not collinear), then how do I determine the coordinates of V = (8, 7)? Is it simply a matter of determining the end point of V relative to the base of V1, and V2 with the tails together?
Phys.Org News Partner Science news on Phys.org
New type of solar concentrator desn't block the view
Researchers demonstrate ultra low-field nuclear magnetic resonance using Earth's magnetic field
Asian inventions dominate energy storage systems
DeadWolfe
#2
May18-08, 04:42 PM
P: 461
In this case the problem is indeed whether or not they are collinear, but more generally the problem is to figure out whether they are independent. As for finding the coordinates of V relative to that basis, what do coordinates mean? The coordinates are two numbers a and b such that
V=aV1+bV2
But if you write this out, it is just a system of two equations in two unknowns, which you should be able to solve.
winston2020
#3
May18-08, 04:55 PM
P: 35
Quote Quote by DeadWolfe View Post
V=aV1+bV2
Thank you. Given what you said, this is what I did:
V = aV1 + bV2
(8, 7) = a(1, 2) + b(3, 5)
Therefore:
8 = a + 3b
7 = 2a + 5b
After solving: a = -(19 / 5), and b = -(38 / 25).
The answer in the book simply says "Yes. (-19, 9)" Can anyone tell me what I'm missing, what I've done wrong here (maybe I just solved a, and b wrong...)?
Vid
#4
May18-08, 05:00 PM
P: 420
You solved the system wrong. Try substituting a = 8 - 3b into the second equation.
winston2020
#5
May18-08, 05:05 PM
P: 35
Quote Quote by Vid View Post
Thanks. The first time I tried substituting b = (7-2(-19/5))/5 into a = 8 - 3b... I just screwed up the fractions. It's all good now though. Thanks everyone
Register to reply
Related Discussions
Inner Product for Vectors in Complex Space Linear & Abstract Algebra 10
Killing vectors on a 3D Euclidean space Special & General Relativity 5
Orthagonal Vectors in 4 Space Calculus & Beyond Homework 2
Vectors in 3 space Calculus & Beyond Homework 3
Vectors and the geometry of space problems Introductory Physics Homework 14
