Inelastic Scattering - Calculate Energy Change
The discussion focuses on calculating the energy change during an inelastic scattering collision between two objects of equal mass. The user presents a detailed analysis using conservation of momentum and energy equations, ultimately deriving the final energy of the incoming object as E_{f}=\frac{E_{i}*Cos(\theta)}{2}. The conclusion drawn is that the assumption of both objects deflecting at the same angle is incorrect, as they deflect at right angles to each other, which affects the energy calculations. The user seeks validation of their solution and feedback on potential errors in their reasoning.
  • Understanding of classical mechanics principles, specifically conservation of momentum and energy.
  • Familiarity with two-dimensional collision dynamics.
  • Knowledge of trigonometric functions and their application in physics.
  • Ability to manipulate algebraic equations and apply the quadratic formula.
  • Study the principles of inelastic collisions in two dimensions.
  • Learn about momentum conservation in multi-body systems.
  • Explore the implications of energy loss in inelastic collisions.
  • Review the application of the quadratic formula in physics problems.
Physics students, educators, and anyone interested in understanding the mechanics of collisions and energy transformations in physical systems.
ajhunte
Can Someone look over this and tell me if the work is correct.
An object comes in with known velocity (v) and known mass (m) moving directly along the x-axis. It strikes another object of the same mass (m) which is stationary. Find the change in energy of the incoming object based on the angle at which it scattered ([tex]\theta[/tex]) and the velocity of the target after the collision (u). The collision only occurs in 2 dimensions. (Note: The angle at which the target object is moving can be removed algebraically.)
[tex]E_{i}[/tex]=Energy of Incoming Object before collision
[tex]E_{f}[/tex]=Energy of Incoming Object after collision
[tex]E_{2}[/tex]=Energy of Target Object after collision
[tex]p_{i}[/tex]= Momentum of incoming object before collision.
[tex]p_{f}[/tex]=Momentum of Incoming object after collision.
[tex]p_{2}[/tex]=Momentum of Target object after collion.
[tex]\phi[/tex]= Arbitrary Angle of Target object scattering (should not matter based on the note.
[tex]E=1/2*m*v^{2}[/tex]
p=m*v
[tex]p^{2}/(2*m)=E[/tex]
Energy Balance:
[tex]E_{i}=E_{f}+E_{2}[/tex]
X-Momentum Balance:
[tex]p_{i}=p_{f}*Cos(\theta) +p_{2}*Cos(\phi)[/tex]
Y-Momentum Balance: (This should be a zero momentum system in y-direction)
[tex]p_{f}*Sin(\theta)=p_{2}*Sin(\phi)[/tex]
Squaring only the Momentum Equations and adding them together.
Y-Balance:
[tex]p_{f}^{2}*Sin^{2}(\theta)=p_{2}^{2}*Sin^{2}(\phi)[/tex]
X-Balance: (after getting [tex]\phi[/tex] isolated on one side then squaring)
[tex]p_{2}^{2}*Cos^{2}(\phi)=p_{i}^{2} - p_{i}*p_{f}*Cos(\theta)+p_{f}^{2}*Cos^{2}(\theta)[/tex]
Adding the two momentum Equations and using [tex]Sin^{2}+Cos^{2}=1[/tex]
[tex]p_{2}^{2}=p_{i}^{2}-p_{i}*p_{f}*Cos(\theta)+p_{f}^{2}[/tex]
Relating back to energy, using the relationship defined in section 2.
Since all masses are the same I divide the newly found momentum equation by 2m in order to get to energy:
[tex]E_{2}=E_{i}+E_{f}-\sqrt{E_{i}}*\sqrt{E_{f}}*Cos(\theta)[/tex]
(Note: [tex]\sqrt{2m}*\sqrt{2m}=2m[/tex] and [tex]p/\sqrt{2m}=\sqrt{E}[/tex] )
Combining with the original Energy Balance Equation to Eliminate [tex]E_{2}[/tex]. This involves subtracting the equation I just solved for and the original equation.
[tex]0=2*E_{f}-\sqrt{E_{i}}*\sqrt{E_{f}}*Cos(\theta)[/tex]
Applying the Quadratic Equation [\b]
[tex]\sqrt{E_{f}}=\sqrt{E_{i}}*Cos(\theta) +\- \frac{\sqrt{\sqrt{E_{i}}^{2}*Cos^{2}(\theta)-0}}{4}[/tex]
Minus Sign Answer Leads to 0, so nontrivial answer is:
[tex]E_{f}=\frac{E_{i}*Cos(\theta)}{2}[/tex]
Is this the correct solution, or is there a step that I made a mistake or false assumption? It seems to me that this is wrong, because even a grazing trajectory decreases the initial energy by 1/2.
I think your error is in assuming they both deflect at the same angle.
Objects always deflect at right angles to each other. That's how you remove the resultant theta of the object that is originally stationary.
https://www.physicsforums.com/latex_images/17/1773673-11.png Right there, look at the p2 term.
