Troubleshooting Computer Power Supply Issues
The discussion revolves around troubleshooting recurring issues with a computer power supply that has burnt out multiple times within a short period. Participants explore potential causes, solutions, and recommendations for replacement power supplies.
  • Exploratory, Technical explanation, Debate/contested
  • One participant expresses frustration over repeated power supply failures and seeks assistance in identifying the cause.
  • Another participant suggests that the issue could be due to insufficient power supply capacity, bad outlets, or misjudgment regarding the condition of the plugs.
  • A third participant recommends determining the voltage requirements of components and suggests increasing the wattage by 50-100 watts for stability.
  • This participant also advises choosing a power supply with dual 12v rails and suggests reputable brands while cautioning against using low-quality power supplies that often come with cases.
  • Another participant reiterates the possibility of a faulty outlet and recommends considering a higher wattage or better quality power supply.
Participants present multiple competing views regarding the cause of the power supply failures and potential solutions. There is no consensus on the exact reason for the failures or the best course of action.
Participants mention various assumptions about the power supply's capacity and the condition of electrical outlets, but these factors remain unresolved. Specific details about the computer's components and usage are not provided.
Individuals experiencing similar issues with computer power supplies, those interested in building or upgrading PCs, and users seeking advice on troubleshooting electrical components may find this discussion relevant.
4-ize
my power supply for the computer has just burnt resently for the second time in less than twom weeks i obviously have to buy anothr one but am a bit hesitant cause i can't figure out y they keep burning nd the fault is not with my plugs please help wer u can...!:biggrin:
Computer science news on Phys.org
Welcome to PF.
Too little information.
You could be just unfortunate.
Or the power supply could be too small for your application.
Or your contention that your plugs are ok could be wrong.
At two weeks you should be able to return or RMA the unit rather than buy a new one.
1) I'd determine the voltage needed by your components, you can do so http://web.aanet.com.au/SnooP/psucalc.php . The wattage given, i'd up that up 50-100 watts, for overhead room and further stability
2) You want a Power Supply that has dual 12v rails, most newer ones have this, If you can get a modular one that would rock as it would help in the cable management inside your PC.
3) Brands you should stick with are Antec, Enermax, PC power Supply & Cooling, ThermalTake, and Zalman. Try to get one that has dual 120mm fans. Good luck, and remember, if you're building or have built a custom rig, toss the power supply that came with the case. They're mostly never good, have only one 12v rail and are cheaply made. Keep us updated.
Perhaps you have a bad outlet in your wall? Otherwise, I would recommend getting a larger wattage or higher quality power supply.
  • · Replies 79 ·
  • · Replies 33 ·
  • · Replies 23 ·
  • · Replies 19 ·
15K
