Flyball governor and force on slider
  • Thread starter Thread starter Sdarcy
    Force Slider
A flyball governor regulates steam turbine speed by using centrifugal force from rotating balls to control steam flow. The balls move outward, affecting a slider linked to a valve that restricts steam when the turbine rotates too quickly. To calculate the force on the slider, one must consider the centripetal force acting on the balls, which can be expressed using angular velocity and radius. The force can be resolved into components along the supporting beams, with the vertical component affecting the slider. Understanding the dynamics of the system is crucial for solving related problems, including calculating the minimum rotation speed for the balls to function effectively.
Sdarcy
http://www.mech.uq.edu.au/courses/mech2210/yat/q/governor.jpg
A flyball governor is a device used to regulate the speed of steam turbines in steam power plants. The rotation of the shaft causes the two balls move outward. As the balls move out, they pull on the bearing A. The position of the slider A is linked to a valve admitting steam into the turbine. This way, the flow of speed is automatically restricted when the shaft starts rotating too fast.
The following data is given for the flyball governor shown in the figure:
L =300 mm
gama= 45 degrees
m = 1 kg (the mass of each ball)
N = 1452 RPM
What is the force (in N) pulling on the slider A if the shaft rotates at the speed given below? Ignore friction and the weights of the conmponents other than the two balls.
I have NO idea where to start with this one! Everything I do just seems to lead in circles and not get me anywhere...Any help would be much appreciated...
In the inertial coordinate system where the flywheel is at rest, there is a centripetal force acting on the balls:
F = m\omega^2 r = m \left(\frac{2\pi}{N}\right)^2 r
which is directed radially away from the axis of rotation, and r is the radius. Use trigonometry to split this force into components directed along the supporting beams and then combine them to find the net resulting force on the bearing. Don't forget to use SI units in your calculation.
I'm not sure how to split the force and recombine it. Do you mind stepping me through it?
Thanks
Let the tension along L be T. Then, projecting
2T\sin \gamma = F\, , \quad 2T = \frac{F}{\sin \gamma}
The factor 2 is because there are two L's. Further, project the forces vertically to find the force on A:
F_A = 2T \cos \gamma = \frac{F}{\tan \gamma}
HI, I found a similar qns and were asked to
a)draw the free body diagram of the ball and sliding collar
b)calculate y which is 2Lcos(gama) in this case, as a function of omega, that is the angular speed.
c)the min speed of rotation for th eball to "fly" (gama > 0)
anyone has any idea/clues on this qns?
thanks.
At first, I derived that: $$\nabla \frac 1{\mu}=-\frac 1{{\mu}^3}\left((1-\beta^2)+\frac{\dot{\vec\beta}\cdot\vec R}c\right)\vec R$$ (dot means differentiation with respect to ##t'##). I assume this result is true because it gives valid result for magnetic field. To find electric field one should also derive partial derivative of ##\vec A## with respect to ##t##. I've used chain rule, substituted ##\vec A## and used derivative of product formula. $$\frac {\partial \vec A}{\partial t}=\frac...
