Fourier Cosine Transform and Complex Exponential Solution for Homework Problem
  • Thread starter Thread starter mhill
    Cosine Fourier
mhill
given 2 functions f and g related by a cosine transform
g( \alpha ) = \int_{0}^{\infty}dx f(x)Cos( \alpha x)
then if the integral
\int_{0}^{\infty}dx f(x)exp(cx)
exists for every positive or negative 'c' then should it be equal to
\int_{0}^{\infty}dx f(x)exp(cx)= \frac{g(ic)+g(-ic)}{2} ??
where i have used the Euler identity to express the cosine as a linear combination of complex
exponentials.
Yes, that should work. Unfortunately, since you chose not to show us what you did, I can't say where you might have made a mistake.
thanks Hallsoftivy.. i think this would be the result since
\int_{0}^{\infty}dx f(x)exp(cx) should be real
then i used Euler's formula so 2exp(cx)Cos(ax)=exp(iax+cx)+exp(-iax+cx)
then somehow (of course this all is completely nonrigorous) expanding the exponential into a real and complex part, the contribution to the integral would come from
Cos(ax+icx) and cos(ax-icx) this kernel is precisely the Kernel of a Fourier cosine transform with complex argument.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
