Ballistics Pendulum Homework: Solving for Velocity After Bullet Emerges
The discussion centers on a physics problem involving a 23 g bullet traveling at 235 m/s that penetrates a 3.8 kg block of wood and emerges at 195 m/s. The key equations used are the conservation of momentum, represented by mv = (m+M)v', and the kinetic energy equation, 1/2(m+M)v'^2 = (m+M)gh. The user initially calculated the block's velocity after the bullet's exit as 1.14 m/s and 230 m/s, but was advised that only the first equation is necessary for solving the problem.
  • Understanding of momentum conservation principles
  • Familiarity with basic physics equations related to motion
  • Knowledge of kinetic energy concepts
  • Ability to perform unit conversions (grams to kilograms)
  • Review the conservation of momentum in elastic and inelastic collisions
  • Study the derivation and application of kinetic energy equations
  • Practice solving similar problems involving projectile motion and collisions
  • Explore the effects of friction on motion in physics problems
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators looking for examples of collision problems in a classroom setting.
12boone
A 23 g bullet traveling 235 m/s penetrates a 3.8 kg block of wood and emerges cleanly at 195 m/s.
If the block is stationary on a frictionless surface when hit, how fast does it move after the bullet emerges?
(1) mv= (m+M)v'
momentum before= momentum after
(2) 1/2(m+M)v'^2 = (m+M)gh
I attempted to solvethis using these two equations and I received an answer for 1.14 m/s and 230 m/s. I am having a lot of trouble even determining how to start this problem. I don't want a quick easy answer but I would like help working through it! Thank You!
(1) mv= (m+M)v'
I attempted to solvethis using these two equations …
Hi 12boone! :smile:
However did you use equation (2)? :confused:
Equation (1) should be enough.
Try again! :smile:
10K
  • · Replies 31 ·
