Understanding Reactive Power in AC Circuits: Impact of Capacitors on Total Q"
In a series AC circuit with a given impedance, both real and reactive power are present. Adding a capacitor in parallel supplies reactive power (vars), which does not change the total real power (P). The total reactive power (Q) is effectively reduced by the capacitor, leading to an improved power factor. This indicates that the capacitor acts as a static reactive power generator, enhancing circuit efficiency. Understanding power factor correction is crucial, as a poor power factor can lead to increased real power losses due to higher current demands.
noumed
Assume a single-phase AC voltage applied to a series circuit with a certain impedance. Because of the real and imaginary part of the impedance, we get both real and reactive power. Now, if we were to connect a capacitor in parallel with the circuit, and if this capacitor supplies a certain amount of vars, what happens to the total reactive power of the circuit? My intuition tells me that:
P(total) is unchanged because the capacitor is purely reactive.
Q(total) = Q(source_before) = Q(source) + Q(cap)
So basically by adding that capacitor, you're reducing the the reactive power supplied by the voltage source, and thus increasing the power factor. Am I right?
Yes, indeed capacitor is a static reactive power generator.:smile:
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
Thanks! =]
You need to look up 'Power Factor Correction".
Poor power factor will increase real power loss because a higher current will flow in the wiring and the generator has to be capable of supplying the higher current.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
