How Is the Total Kinetic Energy of a Car Calculated?
The total kinetic energy of a car and its wheels can be calculated using the formula K_tot = 4(0.5I_CMω² + 0.5MV_CM²) + K_car. In this case, the wheels are modeled as homogeneous cylinders with a weight of 25 kg each and a radius of 0.3 m, while the car itself weighs 1000 kg. The initial calculation mistakenly omitted squaring the speed in the last term, leading to an incorrect total kinetic energy of 82.2 kJ instead of the correct 518 kJ. The correct approach involves ensuring all terms are properly squared and accounted for. Accurate calculations are crucial for determining the total kinetic energy in physics problems.
fishingspree2
The 4 wheels of a car each weigh 25kg and have a radius of 0,3m. Without its wheels, the car weighs 10^3 kg. The wheels are homogenous cylinders. What is the total kinetic energy of the car and the wheels if the car is moving at a speed of 30 m/s?
K_{tot}=4(0.5I_{CM}\omega^{2}+0.5MV_{CM}^{2})+K_{car}
the first to terms of the last question concern the wheels
I_{cylinder}=\frac{MR^{2}}{2}
\omega=\frac{V_{CM}}{R}
replacing omega by V/R, I by MR^2/2 and distributing the 4:
K_{tot}=MV^{2}+2MV^{2}+\frac{10^{3}\times30}{2}
K_{tot}=25\times30^{2}+50\times30^{2}+\frac{10^{3}\times30}{2}=82,2 \mathrm{kJ}
The right answer is 518 kJ
where is the mistake? :(
thank you, sorry for my english
You forgot to square the speed in that last term.
Thank you very much
sorry for the waste
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
