Thread Closed
What's the purpose of "thrust balance" in Turbo Fan Engine?
Share Thread Thread Tools
Dec28-08, 12:31 AM   #1
I'd like to know about the purpose of the Thrust balance system in commercial
Turbo Fan Engine. Can you tell me the major role of thrust balance system?
Also, the relations between thrust balance system and compressor / main bearing.
thank you in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Dec29-08, 09:50 AM   #2
Recognitions:
Thrust balance is a way to ensure the loading on the thrust supporting bearings in an engine stay relatively constant over the operating range of the engine. If not constant, then at least an effort to limit its maximum value. This usually allows for a smaller, less load capacity bearing to be used in applications that would usually require something very large and thus add cost and weight.
There are correlations for sizing the bearing and thrust balance, but it is a process that is really somewhat iterative and relies a lot on the aerodynamics of a particular core and the design constraints for a particular engine. In the end, you are balancing the aerodynamic forces by increasing/decreasing balance piston area and the design constraints, i.e. size, speed, cost, of your thrust loaded bearings. There is a lot of trade offs and experience in this aspect. There is no "plug and chug" equations to do this.
Thread Closed
Thread Tools
Similar Threads for: What's the purpose of "thrust balance" in Turbo Fan Engine?
Thread Forum Replies
perceptual balance and "sea legs" Medical Sciences 17
Congrats to Turbo on "A Catalogue of M51 type Galaxy Associations" General Astronomy 10
Is "selfishness" the only purpose of man?.. General Discussion 29
Purpose of theoretical physics - Was "What's wrong with loop QG" General Physics 7
The difference between "What Cause" and "What Purpose". General Discussion 21
