n0_3sc
- 243
- 1
Are there any analytical techniques to do this besides the Derivative Test?
lukaszh said:But there is also possibility to estimate. If you solve some elementary function, for example:
[tex]f(x)=x^2+3x+2[/tex]
You can transform it to form:
[tex]f(x)+\frac{1}{4}=\left(x+\frac{3}{2}\right)^2[/tex]
So now you are able to find a minimum:
[tex]\min_{x\in\mathbb{R}}f(x)=-\frac{1}{4}[/tex]
A maximum of a function is the highest point on the graph of the function, while a minimum is the lowest point. They are also known as the global maximum and minimum, as they are the largest and smallest values of the function over its entire domain.
To identify the maximum and minimum of a function, you can use the first and second derivative tests. The first derivative test involves finding the critical points (where the derivative is equal to 0 or undefined) and checking if the derivative changes sign at those points. If the derivative changes from positive to negative, the point is a maximum, and if it changes from negative to positive, it is a minimum. The second derivative test involves evaluating the second derivative at the critical points, and if it is positive, the point is a minimum, and if it is negative, it is a maximum.
Yes, a function can have multiple maximum or minimum points. These are known as local maximum and minimum points. They are the highest and lowest points in a specific interval, but not necessarily the overall highest or lowest values of the function.
The absolute maximum and minimum of a function can be found by evaluating the function at the endpoints of its domain and at the critical points. The largest and smallest values obtained from these evaluations will be the absolute maximum and minimum of the function.
Yes, a function can have a maximum or minimum at the endpoints of its domain. This occurs when the function is only defined on a closed interval, and the highest or lowest value of the function is at one of the endpoints.
