Is an Ideal Cycle Possible? Examining Enthalpy Values in a Lab Experiment
  • Thread starter Thread starter skaboy607
    Cycle
An ideal cycle is theoretically unattainable due to inherent irreversibilities in real systems, but experimental results can approach ideal conditions. In a lab setup involving refrigeration, varying evaporator voltage while maintaining constant condenser pressure yielded enthalpy values that were nearly identical for both the actual cycle and the isentropic compression assumption. This unexpected similarity raises questions about the accuracy of the assumptions made in the experiment. The discussion highlights the complexities of thermodynamic cycles and the potential for experimental results to challenge theoretical expectations. Ultimately, while ideal cycles remain a theoretical construct, practical experiments can yield surprising results that merit further investigation.
skaboy607
Is an ideal cycle possible? In a lab experiment that I have carried out, my enthalpy values for the cycle and the cycle assuming isentropic compression look like they are the same. I thought this was impossible but I am doubting myself now?
Thanks
Will
Thanks
Will
An ideal cycle is not achievable in reality due to irreversibilities. However, you may get arbitrarily close. What does your lab consist of exactly?
CS
We had a refrigeration setup and we varied the evaporator volts which varied the pressure whilst keeping the condensor pressure constant. At one particular pressure, the specific enthalpy and specific enthalpy (based on isentropic compression) are very close if not the same.
Will
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
