Acceleration of a Truck Hit by a Water Stream
  • Thread starter Thread starter pchalla90
    Momentum
The discussion revolves around calculating the acceleration of a truck hit by a horizontal stream of water. The water flows at a rate of 600 kg every 10 seconds with a speed of 30 m/s, impacting a 2000 kg truck. The thrust applied by the water changes as the truck accelerates, leading to a non-constant acceleration. Initial calculations led to an incorrect conclusion about the truck's speed, prompting a reevaluation of the integration process. The user expresses gratitude for the assistance received and indicates a need to solve a subsequent part of the problem regarding water entering the truck.
pchalla90
A hose can produce a horizontal stream of water at the rate of 600kg every 10 seconds as the water flows with constant speed of 30 m/s. Assume the water strikes the flat vertical back of a 2000kg truck. The water splashes out along the back of the truck without rebounding and then runs down to the ground. The truck is free to move without friction. What will be the acceleration of the truck in 30 seconds?
thrust=|vdM/dt|
F=ma
okay, so we know that dM/dt=600/10 kg/sec=60kg/sec.
we also know that as the truck speeds up, the relative speed of the stream of water will slow down, so the acceleration is not constant. this means that the thrust applied by the water is also not constant, but dependent on the v of the truck.
so here goes:
thrust=(relative v of water to truck)(dM/dt)=(30-v)(60)kgm/s^2
acceleration of truck=thrust/mass of truck=(1800-60v)/2000
a=dv/dt, so
dv/dt=(1800-60v)/2000
dt=2000dv/(1800-60v)
with a bit of integrating:
t=-(100/3)ln(90-3v)
and rearranging:
v=-(1/3)e^(-3t/100)-30
but when you plug in 30 seconds for t into this equation, you get a number greater than 30, which is physically impossible because the speed of the truck has v=30 as its asymptote.
what am i doing wrong?
thanks for your help.
and another thing: assuming that i have a conceptual error and not a mathematical error, i will also need assistance solving part b of the question:
What will be the acceleration of the truck in 30 seconds if the water can enter the truck through a hole and remain inside?
thanks again.
Integrating your dt=2000dv/(1800-60v)
I get integral from v = 0 to v of 2000/60*dv/(30-v)
Let u = 30 - v, du = -dv to get
integral from u = 30 to 30-v of du/u
t = -2000/60[ln(30-v) - ln(30)]
60t/2000 = ln[30/(30-v)]
30/(30-v) = e^(-60t/2000)
v = 30 - 30*e^(-60t/m)
Note that at time zero, v = 0. In your answer you get v = -1/3 - 30 at time zero.
ahhhh! there we go. so errors with integration...
thank you for correcting me! it works now.
now off to figure out part b.
thanks again!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
