How to Prove Isometries are Surjective on Compact Metric Spaces
  • Thread starter Thread starter minibear
    Isometry
minibear
Let (K, d) and (K', d') be two compact metric spaces and let f:K-->K' and g:K'--->K be isometries. Show that f(K)=K' and g(K')=K
n/a
I know that isometry implies that I can find one-to-one correspondence mapping, but not sure how to show both function and inverse function are subjective. Please help. Thanks!
I can't follow your attempt: we are not looking to 'find' a map. Could you please write out your work in full. It also helps to write out the definitions of the key terms: e.g., isometry, compact.
Are you aware of the theorem which says that an isometry h:X\to X on a compact metric space X is surjective?
If so, the result you want to show is just a corollary of this. If not, then this is a good statement to prove.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
