| Thread Closed |
Regular values of immersion. |
Share Thread | Thread Tools |
| Mar13-09, 12:45 AM | #1 |
Hi:
This problem should be relatively simple, but I have been going in circles, without figuring out a solution: If f:X->R^2k is an immersion and a is a regular value for the differential map F_*: T(X) -> R^2k, where F(x,v) = df_x(v). Then show F^-1 (a) is a finite set. I have tried using the differential topology def. of degree of a map , where we calculate the degree by substracting the number of points where the Jacobian has negative determinant (orientation-reversing) minus the values where JF has positive determinant. I think I am close, but not there. Any Ideas? Thanks. |
| Mar13-09, 12:49 AM | #2 |
Is it enough to say that for regular values, since f is a local diffeomorphism, it is
a covering map?. ( but we could always have infinitely many sheets in the cover...) |
| Mar20-09, 05:14 PM | #3 |
You are right that since your map is a local diffeomorphism the inverse image of any point must be discrete. If X is compact then any discrete subset must be finite. If X is not compact this is not true. For instance the covering of the circle by the real line x -> exp(ix) is an immersion but the inverse image of each point is infinite. |
| Mar20-09, 05:30 PM | #4 |
"Your question confuses me. An immersion I think by definition has all regular values. It Jacobian is a maximal rank everywhere. Maybe you are using a different definition of regular value."
I was just considering the immersion to be in "standard position" for the inverse image of a regular value to be a manifold, but I admit I did not explain that clearly. Still, please put up with some innacuracies for a while, since I am still an analyst in Algebraic topology exile. Hope not for too long |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Regular values of immersion.
| show that there is no immersion of S^n into R^n | Differential Geometry | 2 | ||
| show that { (x,|x|);x is real number} IS NOT the image of an immersion | Differential Geometry | 0 | ||
| regular and non-regular magic squares | Calculus & Beyond Homework | 0 | ||
| Archived thread "Volumes of Regular Icosahedron and Regular Tetrahedron" | General Math | 0 | ||
| Volumes of Regular Icosahedron and Regular Tetrahedron | General Math | 20 | ||
