Finding acceleration of two masses connected by spring horizontally
The discussion focuses on calculating the initial acceleration of two masses connected by a spring with a known spring constant (k) and a coefficient of kinetic friction (µ_k). The equations derived from Hook's Law (F = -kΔx) and Newton's Second Law (F = ma) are used to express the forces acting on each mass. It is concluded that the initial acceleration can be determined using the equations a1 = (kΔx - µ_k*m1*g)/m1 and a2 = (kΔx - µ_k*m2*g)/m2, assuming the spring force exceeds the frictional force. The effect of the masses on each other's acceleration is acknowledged but deemed unnecessary for calculating the initial acceleration.
  • Understanding of Hook's Law and its application in spring mechanics
  • Familiarity with Newton's Second Law of motion
  • Knowledge of kinetic friction and its role in motion
  • Basic algebra for solving equations involving forces and accelerations
  • Study the dynamics of coupled oscillators to understand the motion of connected masses
  • Explore the effects of varying mass ratios on acceleration in spring-mass systems
  • Learn about energy conservation in spring systems to analyze motion over time
  • Investigate the role of damping forces in oscillatory motion
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of spring-mass systems and the effects of friction on motion.
Revivalist
Two masses sit on a horizontal surface and are connected by spring with known spring constant k. There is a known coefficient of kinetic friction µ_k for both blocks. The masses are brought together so that the spring is compressed by an amount Δx and then released. Find the acceleration of each block when they start moving.
Hook's Law: F=-kΔx
Newton's Second Law: F=ma
Friction force: F=µ_k*N
I originally tried to solve the problem by just doing a summation of forces on each block (m1 and m2) using Hook's Law.
ΣF=kΔx - µ_k*m1*g = m1*a1
ΣF=kΔx - µ_k*m2*g = m2*a2
But this simply gives a1 = (kΔx - µ_k*m1*g)/m1 and a similar equation for a2.
However, I realized that the problem with this is that the equation for a1 is treating m2 as a fixed body. But since m2 is going to accelerate in the other direction, this should have an effect on the acceleration of m1 by decreasing the force it experiences from the spring. In fact, I was thinking that the equation should reduce to what I have above only when m2 is vastly greater than m1 because that means m2 would be like a rigid wall compared to m1. Then the equation above should properly describe what is happening to m1.
Likewise, if m1 is vastly greater than m2, I should find that m1 does not accelerate at all and m2 is the only that accelerates. So I'm obviously neglecting the fact that because both masses are accelerating, this needs to be incorporated into the accerlation equations somehow.
I also became confused when I realized that if the blocks are moving then that means the acceleration will actually be changing sinusoidally. However, I am going to assume that the question is asking about the acceleration right at the moment that the blocks start to move. Otherwise, we would have to use a sinsoidal expression for the acceleration and that would be dependent on time.
Any help would be greatly appreciatd. Thanks!
I think that's right.
The fact that the other mass also moves will affect the value of Δx at later times. However, they just want the initial acceleration, and Δx is a given, so what you wrote should be sufficient.
p.s.
Welcome to PF :smile:
Looks good to me. (Assuming, of course, that the spring force is greater than the friction.)
Not really. At any given instant, the force exerted by the spring on each mass depends only on the stretch of the spring.
All you are asked to find is the acceleration at one moment, which you've done. But you are correct that the ultimate motion of each mass depends on the relative size of their masses.
  • · Replies 16 ·
