Electromagnetic Waves and Fields
Electromagnetic waves are described as waves "of" the electromagnetic field rather than waves "in" it, emphasizing that they are regions of space exhibiting wave-like properties. The consensus among physicists is that there is no aether or medium through which EM waves propagate; instead, they travel through space itself. The distinction between waves "of" and "in" relates to the nature of mechanical waves, which require a medium, unlike EM waves that do not involve material movement. While the harmonic dependence of EM fields justifies their wave description, visualizing them remains challenging due to the absence of a physical medium. Ultimately, EM waves create their own fields, independent of any background electromagnetic field.
jmsmith
Hi,
This may ultimately be an opinion question:
When thinking about electromagnetic waves semi-classically, how appropriate is it to describe the waves as propagating through an electromagnetic field? If it is appropriate, how appropriate is it to describe the electromagnetic field as a medium through which electromagnetic waves propagate?
In terms of your specific question, EM waves are waves *of* the EM field, not waves *in" the EM field. I.e., an "EM wave" is a region of space where the EM field has properties that we associate with waves (harmonic oscillations in space and time).
But you are getting really close to asking whether there is an "aether" or "medium" that EM waves move through. I think it's safe to say that nearly all professional physicists agree that there is *not* an aether, and that it is not correct or helpful to think of EM waves as moving through a medium.
However, you should be aware that this view is extremely controversial among some laymen, and I'm sure there are numerous threads here on physicsforums where this is debated ad nauseum.
Thanks for the reply. I am a bit confused by the "of" v. "in" distinction though.
What about a wave on a rope? Why is a wave on a rope a wave "in" the rope, but an electromagnetic wave is a wave "of" the electromagnetic field?
But you did answer my question perfectly on a practical level. When describing an electromagnetic wave, I should NOT describe it as traveling through the medium of an electromagnetic field.
Electromagnetic waves propagate through space, and space has a permeability u0 = 4 pi x 10-7 Henrys per meter and a permittivity e0 = 8.85 x 10-12 Farads per meter.
Sqrt (u0/e0) = 376.730 ohms (impedance of free space), and
1/sqrt(u0 e0)= 2.997924 x 108 meters per sec
I think there's an aspect of this question that is just semantics, but it's not completely semantics :smile:
All (?) of the waves we have direct experience of are mechanical, like your rope example. Also sound waves, water waves. In these cases some material object(s) is *moving*, and we speak of that object(s) as the "medium through which the wave moves" (rope, air, water).
Abstracting away from the specific cases, one thing that all these phenomenon have in common is a harmonic dependence on space and time (*). And of course phenomena like interference and diffraction (which occur in, e.g., water waves) are consequences of this harmonic dependence.
The tricky thing about EM waves is that nothing is moving: there is no medium. So the analogy to rope waves breaks down in this sense! This makes EM waves very difficult / impossible to visualize (did you see my post on Feynman's view of this?).
But there *is* a harmonic dependence on space and time: the magnitudes of the fields have this harmonic dependence. This justifies the description of the electromagnetic phenomenon that we call "light" as a "wave". And of course the phenomenon of light interference and diffraction is a consequence of this harmonic dependence.
Not sure if this is clear, maybe someone else with have another way to think about it.
(*) By "harmonic" I mean sine and cosine. If you want to be more accurate I guess you could say "periodic" dependence, since waves on a rope aren't going to be *exactly* harmonic, but they will be "pretty close". It doesn't really matter for the purposes of this argument.
If the propagation of a EM wave REQUIRED a background EM field you might have a point. It does not, a EM wave creates its own field, and even if there is a background field it does not factor into the propagation of a wave.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
