Sound isolation capacity of an idealized wall construction
The discussion focuses on estimating the sound isolation capacity of a wall structure, emphasizing the importance of wall impedance, mass, and rigidity in sound isolation. The user has calculated wall impedance using specific parameters for a gypsum board wall and is questioning the accuracy of their results. They have derived values for impedance based on mass and rigidity, yielding different sound isolation levels in decibels. The user seeks guidance on whether their calculations are correct and what steps to take next for further analysis. Understanding these factors is crucial for evaluating the sound isolation quality of wall constructions.
sigertdejean
I'm looking to understand how to estimate the sound isolation capacity of a wall structure. With rising degree of detail will probably come an exponantial increase in complexity. I'm looking to start of, euhm,... gently. :shy:
What I've gathered so far:
-The impedance of the wall seems to take center stage
-There's atleast two fundamental aspects of the wall that govern its sound isolating qualities: mass and rigidity, each dominant over the other in a different frequency range
I've posted one of the equations I've tried to solve, hoping someone can shine a light.
A plane wave of single frequency 200Hz traveling through air at 344m/s is obstructed by a single leaf gypsum board wall, 25mm thick, with infinite X and Y dimensions (some wall eh).
Frequency f = 200Hz
Thickness h = 0.025 m
Young’s modulus E = 2,3*10^9 N/m²
Poisson ratio V = 0,33
Mass M = 25 Kg/m²
Speed of sound c = 344 m/s
Angle of incidence φ = Perpendicular to boundary = 1/2π
w = f * 2π
= 200Hz * 2π
= 400π
Rigidity D = (E*h³)/(12*(1-V²))
= (2,3*10^9*0.025³)/(12*(1-0.33²))
= 3360,78
Z = M*w² (wall impedance as a result of its Mass)
= 25*(400π)²
= 39478417,6
=> 20*LOG(39478417,6) = 151,93 dB
Z = D*((w / c)*sinφ)^4 (wall impedance as a result of its Rigidity)
= 3360,78*((200Hz*2π / 344)*sin (1/2π))^4
= 3360,78*(400π / 344)^4
= 598474,66
=> 20*LOG(598474,66) = 115,54 dBMy questions:
1) Are my numbers really off, or is it just me?
2) Assuming I get the impedance right, what would be the next step in determining the sound isolation quality of this idealized wall structure?
*bump*
Another forum perhaps?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
