Simplifying the Trigonometric Expression Question
The discussion revolves around simplifying the trigonometric expression cosx/(secx+tanx). The initial attempt leads to an incorrect denominator, which is corrected to sinx + 1. A hint is provided regarding a relevant identity involving sinx and cosx. The user successfully simplifies the expression to 1 - sinx after applying the identity. The final result is confirmed as correct.
Deaddman
cosx/(secx+tanx)
So far I have this:
=cosx/(1/cosx + sinx/cosx)
=cosx/(sinx + 1/cosx)
=cos2x/sinx + 1
From there I don't know what to do. I've messed around with it for a while but don't seem to get anywhere.
Any help is appreciated.
Your last denominator is incorrect. It should be sinx + 1.
Yeah you're right, thanks for pointing it out. Fixed now.
cos2 x/(1 + sin x)
(Let's keep the order of 1 and sin x.)
Here's a hint: do you know of an identity that has a sin x (or a multiple or a power thereof) and a cos x (as before) in it?
01
Ahhh, I think I got it.
1-sin2 x/1+sin x
(1-sin x)(1+sin x)/1+sin x
1-sin x!
Right?
Indeed that is correct!01
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
