What is the ball's maximum acceleration?
The discussion centers on calculating the maximum acceleration of a 160 g ball attached to a spring with a spring constant of 2.8 N/m. The initial calculation yields an acceleration of 78.75 cm/s² using the formula a = kx/m. However, participants note that the spring constant's units (N/m) and the velocity's units (cm/s) must be consistent. To determine the maximum acceleration, it's suggested to find the maximum displacement (x_max) using the given velocity. The conversation emphasizes the need to correctly apply the principles of oscillation and unit conversion for accurate results.
lijoeman
A 160 g ball attached to a spring with spring constant 2.8 N/m oscillates horizontally on a frictionless table. Its velocity is 20 cm/s when x_0 = 4.5 cm.
a_max = _______ cm/s^2
2. The attempt at a solution
Using F = ma and F = kx
kx = ma
a = kx/m
Substituting the appropriate values
a = (2.8)(4.5)/(.16) = 78.75 cm/s^2
Am I missing something here?
kx = ma
a = kx/m
check your units. your spring constant is in N/m, while you're speed is in cm/s
kx = ma
a = kx/m
That gives you the acceleration at some particular value of x. It will only be a_max when x = x_max.
How can you find the maximum value of x? Hint: Make use of the speed that was given.
