Why Is My Calculation of Rotational Inertia Incorrect?
The discussion revolves around calculating the rotational inertia of three balls with different masses attached to a massless rod. The initial calculations yield a total rotational inertia of 3ML²/2, while the provided answer is 3ML²/4, leading to confusion. Participants agree on using the moment of inertia formula I = Σ(mir²) but suspect an arithmetic error or a flaw in the answer key. There's speculation about whether the distribution of mass in a sphere for the largest mass might affect the calculation, but the lack of a specified radius suggests it should not. The conversation highlights the importance of careful arithmetic and clarity in problem statements.
sskk221
Three identical balls, with masses of M, 2M, and 3M, are fastened to a massless rod of length
L as shown. The rotational inertia about the left end of the rod is:
http://img13.imageshack.us/img13/1424/1234sjy.jpg
I = MR^2
I total = (3M)(0)^2 + (2M)(L/2)^2 + (M)(L)^2
I total = 3ML^2/2
It says the answer is 3ML^2/4 though. Thanks for the help
Likes MD SHAHARIAZ ALAM
Hmm...
<br /> I = mr^{2}<br />
<br /> I = (3M)0^{2} + 2M(\frac{L}{2})^{2}) + ML^{2}<br />
Therefore;
<br /> I = \frac{1}{2}ML^{2} + ML^{2}<br />
<br /> I = \frac{3}{2} ML^{2}<br />
I get the same as you.
The definition of the moment of inertia is;
SUM( miri2 ) So I'm preaty certian that we are following the correct method. So perhaps it is some arithmetical mistake we are both making.
2/4 is 1/2 yes and 1/2mr2 + mr2 is mr2(1/2 + 1)
(1/2 + 1) = 3/2. Nope. I think your answer book might be flawed.
UNLESS you are meant to use the distribution of mass in a sphere for the first mass (3M). Mindyou, because they havn't given you a radius for the sphere I would assume not.
Haths
