science.girl
- 103
A battery with emf \epsilon and internal resistance r is connected to a variable resistance R at points X and Y. Varying R changes both the current I and the terminal voltage Vxy. The quantities I and Vxy are measured for several values of R and the data are plotted in a graph, as shown above on the right.
a. Determine the emf \epsilon of the battery.
b. Determine the internal resistance r of the battery.
c. Determine the value of the resistance R that will produce a current I of 3 amperes.
d. Determine the maximum current that the battery can produce.
e. The current and voltage measurements were made with an ammeter and a voltmeter. On the diagram below, show a proper circuit for performing these measurements. Use A to represent the ammeter and V to represent the voltmeter.
**Diagram is #4 from this link: http://mrmaloney.com/mr_maloney/ap/past-AP-tests/BII_91.pdf
\epsilon = IR + Ir
\DeltaV = IR
a) I know a battery is a constant source of emf.
\epsilon = IR + Ir
\epsilon = \DeltaV + Ir
From the diagram:
\epsilon = (4-2) + Ir
Help! What values do I use?
