Thread Closed
Calculate double integer
Share Thread Thread Tools
May25-09, 03:55 PM   #1
This was a problem on a final test I took this april in Reykjavík University and I whould be greatful if you could help me with it.
Let f(x,y)=2x*cos(y^4) be a function and let D be area in R^2 defined by 0≤x≤1 and x^(2/3)≤y≤1.
Calculate the double integer:
∫∫f(x,y)dA
2. Relevant equations
3. The attempt at a solution
∫dx∫2x*cos(y^4)dy
I have tried to use substitution but that doesn´t lead me anywhere.
I also tried to solve it this way...
∫dy∫2x*cos(y^4)dx which leads to...
∫dy*(x^2*cos(y^4)) and when I add in for x...
∫dy*cos(y^4) and if I use substitution now I will get...
1/4*∫cos(u)du and the final answer isn´t sufficient...
1/4*(sin(1)-sin(x^(8/3)))
I would be very greatful if you could help me...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May25-09, 04:12 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Carefully draw a sketch of the region. Now when you integrate dx, what will be the upper and lower limits of the integration in terms of y?
May25-09, 06:00 PM   #3
the upper limits are 1 and lower limits are x^(2/3) in terms of y
and upper limits are 1 and lower limits are 1 in terms of x
May25-09, 06:52 PM   #4
Recognitions:
That's not what my picture looks like. The integration dx goes along a horizontal line through the region. It's the part above (above being the positive y direction) the curve x^(2/3)=y. Want to try again?
May26-09, 09:20 AM   #5
I have no clue...:S
May26-09, 09:30 AM   #6
Recognitions:
The region inside of the square 0<=x<=1 and 0<=y<=1 above the curve y=x^(2/3). Pick a value of y and draw a horizontal line. Tell me what the x value is where it crosses the region. It looks to me like it will hit the y-axis first and then the curve, right?
May26-09, 09:45 AM   #7
The problem requires you to change the order of integration. The limits that are given have you integrating with respect to y first.
Thread Closed
Thread Tools
Similar Threads for: Calculate double integer
Thread Forum Replies
why double integral could calculate area and volume.. Calculus & Beyond Homework 2
Proof Question: Prove integer + 1/2 is not an integer Calculus & Beyond Homework 4
Prove that the inverse of an integer matrix is also an integer matrix Precalculus Mathematics Homework 7
Every integer can be written as a sum of a square and square free integer Calculus & Beyond Homework 5
Double dual/Double Transpose Question Calculus & Beyond Homework 10
