Chromatic number of the n-cube
  • Thread starter Thread starter Dragonfall
The chromatic number of the n-cube is established as 2, indicating that it is a bipartite graph. For both the square and the 3-cube, this holds true, supported by empirical evidence. The vertices of the n-cube can be labeled using vectors in {0, 1}^n, allowing for a clear partition based on the parity of the number of 1's. This bipartite nature confirms that only two colors are needed for proper vertex coloring. Thus, the discussion concludes that the chromatic number of the n-cube is definitively 2.
Dragonfall
What is the chromatic number of the n-cube? As a graph, I mean. For the square and 3-cube, for example, it's 2.
Mathematics news on Phys.org
Empirical evidence suggests it's just 2.
The n-cube is bipartite, so its chromatic number is 2. If we label the vertices canonically with vectors in \{0, 1\}^n, then we can partition the vertices into those with an even number of 1's and those with an odd number of 1's.
Oh ya, thanks.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
