| Thread Closed |
Optics: Leveling Components |
Share Thread | Thread Tools |
| Jul23-09, 04:32 PM | #1 |
I have a apparatus with a thin electrode that is suppose to be parallel with surface beneath it. I can level the surface, but you cannot put a level on this electrode.
I was thinking have like a block precisely made to the expected distance between the electrode and bottom to determine the alignment, but I was thinking if I was not careful I could damage the electrode. Another thought, maybe use a laser level and calibrated to the level surface, then some how move it up to the elevation of the electrode to check its alignment. However, I have heard that even the levels used by contractors are not very precise and can be quite cumbersome in those applications. I was wondering if there is any specialized instrumentation and/or produces used in the laboratory setting. I figure those who work in optics have developed something, but I cannot find any information on the issue. I would prefer to get some direction/recommendation for literature and documentation. Thank You |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jul23-09, 04:53 PM | #2 |
Recognitions:
To get it parallel you can either measure the distance electrode-substrate at each end
Using something like this http://www.sensorland.com/HowPage056.html is fairly cheap and accurate to <1um and non-contact. Or you can use an old fashioned travelling microscope to do the same thing. Another apporach if your electrode is reflective enough is to shine a laser at each end (eg slide the unit under a fixed laser) and measure the distance apart the reflected spots appear on the ceiling. With a bit of trig and assumign the position of the laser is fixed you can work out the slope of the electrode. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Optics: Leveling Components
| Angle Of Deviation - An Optics Problem, help needed in optics | General Physics | 6 | ||
| car components... | Materials & Chemical Engineering | 0 | ||
| i and j components | Introductory Physics Homework | 2 | ||
