How Do You Calculate P(Y>0.5|Y>X^2) for Uniformly Distributed Variables?
  • Thread starter Thread starter cse63146
The calculation of P(Y>0.5|Y>X^2) for independent uniformly distributed variables X and Y on the interval (0, 1) involves evaluating the conditional probability using integrals. The correct formulation is P(Y > 0.5 ∩ Y > X^2) / P(Y > X^2), which simplifies to the integral expression: ∫(1/2 to 1) ∫(0 to √y) dx dy divided by ∫(0 to 1) ∫(0 to √y) dx dy. The final computed probability is approximately 0.6465, confirming the proper bounds for x in the integrals.
  • Understanding of conditional probability
  • Familiarity with integration techniques
  • Knowledge of uniform distribution properties
  • Ability to work with double integrals
  • Study conditional probability in depth
  • Learn about double integrals and their applications
  • Explore properties of uniform distributions
  • Investigate common mistakes in probability calculations
Students in statistics or probability theory, mathematicians working with uniform distributions, and anyone involved in solving conditional probability problems.
cse63146
X and Y are independent and uniformly distributed on the unit interval (0, 1)
Determine P(Y>0.5|Y>X^2)
I set it up as the following: [tex]\frac{P(Y > 0.5 \cup Y > X^2)}{P(Y > X^2)}<br /> = \frac{\int^1_{1/2} \int^{\sqrt{y}}_0 dx dy}{\int^1_{0} \int^{\sqrt{y}}_0 dx dy}[/tex]
for the final answer I got ~0.6465. Did I make any mistakes?
The only thing that's bugging me is whether or not x is properly bounded in the integral. In the question y > x^2, so I assumed the square root of y is also greater than x. And since x is between 0 and 1, I believe that 0<x<sqrt(y)
Your answer looks fine to me, but the union in this probability
[tex]\frac{P(Y > 0.5 \cup Y > X^2)}{P(Y > X^2)} = \frac{\int^1_{1/2} \int^{\sqrt{y}}_0 dx dy}{\int^1_{0} \int^{\sqrt{y}}_0 dx dy}[/tex]
should be an intersection
[tex]\frac{P(Y > 0.5 \cap Y > X^2)}{P(Y > X^2)} = \frac{\int^1_{1/2} \int^{\sqrt{y}}_0 dx dy}{\int^1_{0} \int^{\sqrt{y}}_0 dx dy}[/tex]
Thanks for the correction.
