| Thread Closed |
Excel VBA:: Run Time Error '13' Type MisMatch?? |
Share Thread | Thread Tools |
| Aug5-09, 04:38 PM | #1 |
I keep getting this error when I run this code. Nothing is highlighted..and VBA help is not working out for me.
It just started when I added the for loop in bold below: Code:
Option Explicit
Option Base 1
Private Sub MathML_Converter()
Dim i As Integer
Dim j As Integer
Dim NumElements As Integer
Dim Text As String
Dim MyArray() As String
Dim MyNewArray() As String
'Clear ActiveSheet
Sheets("Sheet1").Range("1:65536").ClearContents
Open "C:\Documents and Settings\Owner\Desktop\APC_Related\MathML.txt" _
For Input As #1
i = 1
Do While Not EOF(1)
Text = Input(1, #1)
ReDim Preserve MyArray(i)
MyArray(i) = Text
Cells(i, 1) = Text
i = i + 1
Loop
Close #1
NumElements = i - 1
' MsgBox "Number of Elements SHOULD be " & NumElements
' MsgBox "Number of Elements IS " & UBound(MyArray)
'Eliminate WhiteSpace From MyArray
j = 1
For i = 1 To NumElements
ReDim Preserve MyNewArray(j)
If MyArray(i) <> " " Then _
MyNewArray(j) = MyArray(i) & _
j = j + 1
Next i
)?Thanks |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Aug5-09, 07:06 PM | #2 |
I have not used any VB in a while but I would say on the 3rd line after the for it might be trying to concantenate or add the j=j+1 to the element of the array.
| Aug5-09, 07:53 PM | #3 |
I agree with Ronnin. I would do it this way:
Code:
j = 1
If MyArray(i) <> " " then
j = j + 1
EndIf
Next i
| Aug5-09, 08:20 PM | #4 |
I noticed that you redim preserve the array on each pass of the loop. Your code would run faster if you precount the number of elements required beforehand and redim the new array before starting the loop.
Code:
j = 0
For i = 1 to NumElements
j = j + 1
EndIf
next i
ReDim MyNewArray(j)
j = 1
j = j + 1
EndIf
Next i
| Aug19-09, 11:01 AM | #5 |
I get the same error when I run the following code. If I comment out the lines in bold, the error goes away, but then the code doesn't do what I want! Any suggestions? Thanks in advance for any help you can give me. I'm no VBA expert and I'm hoping I'm just missing something that's obvious to others.
Code:
Private Sub CommandButton1_Click()
Dim i As Integer 'row index variable
Dim scount As Integer
Dim score As Integer
Dim coffset As Integer
Dim leftcount As Integer
Dim j As Integer 'column index variable
Dim LastCol As Integer
i = 4
Do While i < 6
coffset = 2
scount = 0
leftcount = 1
With ActiveSheet
LastCol = .Cells(i, .Columns.Count).End(xlToLeft).column
End With
j = LastCol
Do While coffset < 22
score = Cells(i, j)
j = LastCol - leftcount
If j > 60 Then
If score > 0 Then
Cells(i, coffset) = score
scount = scount + 1
coffset = 2 + scount
End If
End If
leftcount = leftcount + 1
Loop
i = i + 1
Loop
End Sub
| Sep7-09, 06:54 PM | #6 |
In the highlighted code above, you are assuming that the value in the score variable is a number, whereas it is probably a string. You may need to convert it.
| Dec3-09, 06:56 AM | #7 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Excel VBA:: Run Time Error '13' Type MisMatch??
| excel, error of trend line? | Math & Science Software | 2 | ||
| Error Analysis On Excel Questions | Introductory Physics Homework | 2 | ||
| Expectations for Type I Error | Set Theory, Logic, Probability, Statistics | 4 | ||
| Parallax error - what type of error is it? | General Physics | 5 | ||
| Excel help with error bar formula | Set Theory, Logic, Probability, Statistics | 1 | ||
