New Reply
Relationship between temperature and resistance
Share Thread
Aug31-09, 11:19 PM   #1
1. Well, we want to find the relationship between resistance and temperature. We asked the lab techie and he said to use some Nichrome wire in a coil and test the potential difference, current and temperature of the wire.
We're having a problem getting it set up. We're not sure how to set up the circuit.
2. N.A.
3. We've tried having a power pack that goes into the wire then back into the power pack, and the wire gets hot. Are we doing this right? Could someone please help us out with a circuit diagram or something?
Thanks a lot guys.
2. Relevant equations
3. The attempt at a solution
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Aug31-09, 11:20 PM   #2
2. N.A.
Thanks a lot guys.
Aug31-09, 11:22 PM   #3
Recognitions:
Homework Helper Homework Help
Connect the ammeter in series and the voltmeter in parallel. Not too sure how you plan to measure temperature though. Unless you have a resistor that is affected by temperature.
Sep1-09, 02:19 AM   #4
I think this pdf might help you: http://www.owlnet.rice.edu/~phys102/Lab/expt03.pdf
It is the lab manual for a resistivity experiment for PHYS 102.
Cheers.
Oct20-11, 02:46 PM   #5
Maybe you could use a thermistor as a temperature sensor.
New Reply
Tags
forums, nichrome, physics, resistance, temperature
Similar discussions for: Relationship between temperature and resistance
Thread Forum Replies
Resistance / Frequency relationship Classical Physics 7
relationship between angular speed and temperature General Physics 0
Is there a relationship between temperature and gravity General Physics 3
Voltage, Current, Resistance Relationship Introductory Physics Homework 9
Relationship of temperature and radius. Introductory Physics Homework 2
