Surface tension of an ant on water
An ant weighing 5 mg requires 0.5 mm of edge to walk on water due to surface tension. The discussion revolves around whether the relationship between edge length and weight is linear, with participants questioning the term "edge" in this context. It is clarified that "edge" refers to the perimeter of an area, which is crucial for calculating the necessary surface tension support for larger weights. Concerns are raised about whether surface tension can support a human weighing 50 kg, emphasizing the importance of the edge length in this calculation. The conversation highlights the complexities of applying surface tension principles to different weights.
engineer23
An ant weighs 5 mg and requires 0.5 mm of edge to "walk on water" with the aid of surface tension. How much edge is required for a human who weighs 50 kg?
I'm assuming that the relationship between area and weight is linear in this case. Is this a correct assumption?? If so, then I know how to work the problem.
yes,are directly proportional to weight
CAn you explain meaning of edge, I've never used this term in surface tension problems.
And in my view surface tension can't bear 50kg force.
Think of 'edge' as the perimeter of an area.
Wouldn't that depend on how much 'edge' you have? (That's the point of the exercise.)
(Note that you are responding to a post that is over a year old.)
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
