Line passes through a point parallet to parametric equations
The discussion revolves around finding a line that passes through a specific point P(-1, 4, 3) and is parallel to a given parametric line defined by the equations x = 1 + 3t, y = 2 + 4t, z = 3 + 5t. The goal is to determine the intersection points of this new line with the coordinate planes.
  • Participants discuss how to derive the parametric equations for the new line while ensuring it is parallel to the original line. There is some confusion about the relationship between intersection points and parallel lines.
Some participants have provided guidance on finding the parametric equations for the new line, while others express uncertainty about how to approach the problem of maintaining parallelism. The conversation indicates that multiple interpretations of the problem are being explored.
Participants are navigating the constraints of the problem, particularly regarding the definitions of parallel lines and intersection points with coordinate planes. There is an emphasis on ensuring clarity in the setup of the new line based on the given point and direction.
megr_ftw
Consider the line which passes through the point P(-1, 4, 3), and which is parallel to the line x = 1 + 3t, y = 2 + 4t, z = 3 + 5t
Find the point of intersection of this new line with each of the coordinate planes:
xy-plane: ( , , 0 )
xz-plane: ( , 0 , )
yz-plane: ( 0 , , )
I can figure out the whole intersection thing, I just don't understand how I'm suppose to make it parallel to a line at the same time.
I think you're approaching this in the wrong order. First, find the parameteric equations for the line through (-1, 4, 3), then figure out where this line intersects the coordinate planes.
Hi megr_ftw! :smile:
I don't understand what you're saying here :confused:
an intersection is a point, it can't be parallel to a line (or to anything).
You're asked what is the line through P parallel to the given line. :smile:
so how do i go about finding that line that is parallel but passes through the certain point?
So the line in question is parallel to this line:
[tex]\hat{r}=\left(<br /> \begin{array}{c}<br /> 1 \\<br /> 2 \\<br /> 3<br /> \end{array}<br /> \right) + \left(<br /> \begin{array}{c}<br /> 3 \\<br /> 4 \\<br /> 5<br /> \end{array}<br /> \right)t[/tex]
Since it passes through the given point as described it must be that the new line is this?
[tex] <br /> \hat{s}=\left(<br /> \begin{array}{c}<br /> -1 \\<br /> 4 \\<br /> 3<br /> \end{array}<br /> \right) + \left(<br /> \begin{array}{c}<br /> 3 \\<br /> 4 \\<br /> 5<br /> \end{array}<br /> \right)t[/tex]
Intersection of the planes will be found in the instance that:
[tex]3t - 1 = 0[/tex]
[tex]4t + 4 = 0[/tex]
[tex]5t + 3 = 0[/tex]
For yz-,xz- and xy-planes.
To find the co-ordinates the values found for t need be plugged into the line s.
