What is the meaning of "Effective logic inversion"?
  • Thread starter Thread starter aspsrilanka
    Inversion Logic
Effective logic inversion refers to the relationship between TTL IC outputs and the LED loads they drive, where TTL outputs are more effective as current sinking rather than sourcing. This means that for optimal LED operation, the LED should be connected to +5 volts on one end and to a TTL current sinking output on the other. The term "inversion" highlights that the LED is activated when the TTL output is low, making it an "active low" configuration. Understanding this concept is crucial for students working with TTL circuits and LED applications. Overall, effective logic inversion is key to ensuring proper LED functionality in TTL logic systems.
aspsrilanka
What is the mean of " Effective logic inversion " ?
Because I can't understand this qustion,
" Describe briefly why there is an Effective logic inversion between logic level from a TTL IC and the LED load it drives? "
Hello aspiralanka-
One conceptual problem some students have with understanding TTL is that outputs are better as current sinking outputs than as current sourcing outputs. So driving a LED is better done by tying one end of the LED to +5 volts and the other to a TTL current sinking output.
Bob S
... and the "inversion" in your question refers to the fact that the drive of the LED is "active low". That is, the output of the gate is low (for the reason that Bob mentioned) to turn ON the LED.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
