60hz AC device in a 50hz country
  • Thread starter Thread starter tman25
    Ac Device
Using a 60Hz AC device in a 50Hz country can lead to performance issues, as the motor may rotate 17% slower unless it is a universal motor. Although the device is listed as having a universal motor, it is specified for 60Hz operation, raising concerns about compatibility. Voltage differences are also critical; devices designed for 110 volts may run too fast or not function at all when connected to 230-250 volts commonly found in 50Hz countries. Additionally, devices with series wound DC motors may operate on both frequencies, but speed control features might fail due to specific capacitors. Universal motors can run faster at 50Hz than at 60Hz, complicating the use of such devices in different frequency environments.
tman25
I've heard that frequency differences can cause the motor to rotate 17% slower than it normally would... UNLESS it is a universal motor.
The device in question is listed as running on a universal motor, but is also listed as AC / 60hz only.
Does this still apply?
Thanks.
The main problem might be that most 50 Hz countries also use 230 -250 Volts. So, if the 60 Hz tool is built for 110 volts, it could run VERY fast and then not work at all.
Devices that use series wound DC motors on AC will work at 50 Hz or 60 Hz although some electric drills use a speed control that only works on AC. This depends on inbuilt capacitors that mean it may not work properly on the wrong frequency.
Devices that use power transformers may run hot on a lower frequency because the transformer will have less reactance at the lower frequency.
Hi tman-
A universal motor's impedance is partially resistance and partially inductance. For a fixed RMS voltage, a universal motor will run faster on 50 Hz than 60 Hz.
Bob S
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
