Entropy & second law of thermodynamics
In isothermal contractions of an ideal gas, the change in entropy decreases, contradicting the initial assumption that it cannot decrease. The correct answer is D, as the process involves heat energy flowing out of the gas, resulting in a negative Q value. This leads to a decrease in entropy, despite the average kinetic energy of the gas molecules remaining constant. The confusion arises from the distinction between closed systems and the specifics of isothermal processes. Understanding these principles clarifies the behavior of entropy in this context.
sskk221
Consider all possible isothermal contractions of an ideal gas. The change in entropy of the gas:
A) does not increase for any of them
B) increases for all of them
C) is zero for all of them
D) decreases for all of them
E) does not decrease for any of them
\Delta S\geq 0
\Delta S = Sf -Si
\Delta S = Q/T (isothermal process)
I chose answer E since my physics book states that "in a closed system, the entropy of the system increases for irreversible processes and remains constant for reversible processes. It never decreases." However, the answer key has the correct answer as D. I think it might have something to do with the isothermal modifier, but I'm not exactly sure of the logic.
It's not a closed system when you perform an isothermal process on an ideal gas - you have to supply or remove heat from the system.
In an isothermal contraction, the entropy decreases, as while the average kinetic energy of the molecules remain the same, the gas now occupies a smaller volume - no of states decreases.
\Delta S\geq 0
\Delta S = Sf -Si
When the gas contracts during an isothermal process heat energy flows out of the gas. Thus, Q is negative and so is DeltaS=Q/T. Therefore, the entropy S decreases.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
