Tension, 2 masses, 2 cords hanging vertical
  • Thread starter Thread starter gablec2
    Tension Vertical
To find the tensions T1 and T2 in the strings supporting two blocks of mass 3.50 kg each in an upward-accelerating elevator, apply the formula ΣF = ma. For block #1, the equation T1 - m*g = m*a can be used, while for block #2, T2 - m*g = m*a applies. To determine the maximum acceleration before the first string breaks, set the tension equal to the maximum allowable tension of 87.0 N and solve for acceleration. The discussion emphasizes the importance of free body diagrams in visualizing forces acting on the blocks. Understanding these principles can serve as a template for solving similar physics problems.
gablec2
Two blocks each of mass m = 3.50 kg are fastened to the top of an elevator as in the figure below.--- this is a horizontal version because I am on a comp. [top of elevator]--string1--[block #1 3.5kg]--string2--[block #2 3.5kg]
(a) If the elevator accelerates upward at 1.6 m/s2, find the tensions T1 and T2 in the upper and lower strings.
(b) If the strings can withstand a maximum tension of 87.0 N, what maximum acceleration can the elevator have before the first string breaks?
m/s2
first time here, HELP!
You can start by drawing the free body diagram of the individual strings
I did, but I need some serious help aka answer. I have 2 free body diagrams.
Can you give me the formulas to complete the question.. also using it as a template for other problems
thanks
Well the only 'template' i can think of will be \sum F=ma where F is all the forces acting on a object. For your case T-mg=0 when they are in equilibrium aka not moving and T-mg=ma when they are moving and the 'a' will be the acceleration of the object.
