Tension problem involving picture frame
The discussion focuses on solving a tension problem involving a picture frame suspended by two wires. Participants emphasize the importance of drawing a free body diagram to analyze the forces acting on the frame. The tension in each wire is stated to be 0.75 times the weight of the frame, leading to the conclusion that the vertical components of the tensions must equal the weight of the frame. By breaking down the tension into vertical and horizontal components, the net vertical component can be equated to the weight to find the angle θ. The conversation highlights the need to balance the forces and solve for the angle using trigonometric relationships.
Chandasouk
A picture frame hung against a wall is suspended by two wires attached to its upper corners.
If the two wires make the same angle with the vertical, what must this angle be if the tension in each wire is equal to 0.75 of the weight of the frame? (Neglect any friction between the wall and the picture frame.)
I have no idea what to do except for to draw a free body diagram.
Find the vertical and horizontal components of both the tensions.
Horizontal components cancel each other. Net horizontal components = ...?
the X components would be cos\theta*.75 ?You mean the vertical components cancel each other out right?
Sorry. I mean net vertical component.
If θ is the angle of T with vertical, then check the x component.
What is y component?
Sin\theta*.75 ?
If I broke the tension into components, I get a triangle with theta above the horizontal
In the problem it is stated that "If the two wires make the same angle with the vertical'
If you call this angle as θ, then
vertical component is T*cosθ and horizontal component is T*sinθ.
Horizontal components are equal in magnitude and opposite in direction. Hence they cancel each other.
The net vertical component is the weight of the frame.
okay, I understand that now, but how do I find the angle? The tension on both wires are .75 of the weight, so could I substitute
vertical component is .75w*cosθ
Two vertical components are there. Find net vertical component and equate it to the weight of the frame w. And solve for θ.
