Electron Density: Do They Become More Dense When Cold?
Electrons do not become more dense when cooled; rather, the density change is related to the material they are in, such as a wire or an electron gas. In a wire, as it cools, the entire structure becomes denser, which may slightly affect the electrons trapped in the crystal lattice. An electron gas could theoretically become denser with cooling, assuming constant pressure, but electrons cannot form a Bose-Einstein condensate because they are fermions and cannot occupy the same quantum state. The discussion also touches on the confusion regarding the concept of electron density and the volume of an electron, which is not well-defined. Overall, the behavior of electrons in different states and conditions is influenced by their quantum properties and the material context.
cragar
In my physics class today my teacher was wondering when electrons get colder do they become more dense . So do electron become more dense if the get colder.
What do you mean by more dense? What is the volume of an electron? Or do you propose to discuss a collection of electrons, like an electron gas?
well my teacher was originally talking about electrons in a wire what would happen if the wire got colder . what would happen to an electron gas . If we got the electron gas cold enough could it become an Einstein-Bose condensate.
Sure, I think an electron gas would get denser as it cooled, if other factors like the pressure were kept the same. That's generally true for gasses. The electrons in a wire might also get a little denser as the wire cools, but only because the entire wire is getting denser. Those electrons are trapped within a crystal lattice whose density changes only a little with temperature.
However, you could never make a Bose-Einstein condensate out of electrons, because electrons are not bosons - they're fermions. That means that no two electrons can be in the same quantum state. And a system has to have a significant fraction of its particles all in the same quantum state (the lowest-energy state) to be considered a Bose-Einstein condensate.
I see thank-you for your response.
i no that mass of the electron is 9.1 x 1o-19
volume i jus dun no?
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
