| Thread Closed |
Relating pressure and height in a container |
Share Thread | Thread Tools |
| Nov14-09, 12:45 PM | #1 |
1. A container of uniform cross-sectional area A is filled with liquid of uniform density rho. Consider a thin horizontal layer of liquid (thickness dy) at a height y as measured from the bottom of the container. Let the pressure exerted upward on the bottom of the layer be p and the pressure exerted downward on the top be p+dp. Assume throughout the problem that the system is in equilibrium (the container has not been recently shaken or moved, etc.).
Since the liquid is in equilibrium, the net force on the thin layer of liquid is zero. Complete the force equation for the sum of the vertical forces acting on the liquid layer described in the problem introduction. 2. 0 = sum of forces in y direction 3. Ok, I know that F_up = pA F_down = A(p + dp) weight of the thin layer = pAg dy So I did: pA - A(p+dp) - pAgdy = -Ap(d + dyg) = 0 And it's telling me that the answer does not depend on d. |
| Nov14-09, 01:00 PM | #2 |
Mentor
When you set up your equation, you won't have a 'd' by itself. |
| Nov14-09, 01:14 PM | #3 |
My bad, yes it's rho*Ag dy Thus: F = F_up - F_down - rho*Agdy = pA - A(p + dp) - g*rho*A dy = -dp - g*rho*A dy which is incorrect |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Relating pressure and height in a container
| Relating unsteady flow to height | Advanced Physics Homework | 3 | ||
| Height and Pressure Relating the Two | Introductory Physics Homework | 21 | ||
| Pressure of gases in a container | Classical Physics | 1 | ||
| pressure at the bottom of a container | Introductory Physics Homework | 1 | ||
| relating coefficients of volume, linear expansion with height | Introductory Physics Homework | 0 | ||
