Micro Processor project making a Gun Chronograph
The project involves creating a gun chronograph using four QRB1134 reflective sensors to measure the velocity of a projectile, with the sensors set in pairs at a specified distance. The MEGA16 microprocessor will control the timing and calculations, displaying the results on a CRT. For accurate speed measurements, the timing clock frequency must be sufficient based on the distance between sensors and the speed of the projectile. It is recommended to utilize interrupts and the microprocessor's internal timer for effective timing management. Starting with research on interrupts and timer/counter functions will help in programming the device.
ajaustin12
I need a little help with a lab project that I am making for my Micro Processor class. My instructor gave me the idea of making a gun chronograph.
He wants me to use 4 qrb1134 reflective sensors to detect an object. The qrb1134's will be in two pairs set at a certain distance apart. The purpose for these sensors are to start and stop an internal clock of a MEGA16 micro processor trainer board.
I am also supposed to write a program for the MEGA16 to perform that function and to calculate the velocity of the object that passed through the two pairs of QRB1134. The program is also supposed to display the velocity on the CRT.
I am very new at programing and really don't know where to begin. Any help will be appreciative.
First, you need to know how far apart the sensors are, and how accurately you need to measure the speed. For example, if the sensors are 10 meters apart, the bullet speed is 1000 meters per second, and you need to measure the speed to 1 m/s, then you will need a timing clock ~ 200 kHz or better.
Bob S
I guess I should have been a little more specific. Sorry about that.
Since this is a class assignment i will be using a rubber band or some type of projectile with a rubber band.
I haven't decided the distance between the two pairs of sensors, but thought about putting them about a foot apart.
If the projectile is moving at 100 feet per second, the time delay between sensors spaced one foot apart is 10 milliseconds. If you want a 1% measurement of its speed, then your clock should be roughly 0.5 x 0.01 x 10 milliseconds = 1/50-microseconds, or 20 KHz.
Bob S
To use a uP for a timing task like this, you should probably use interrupts and the uP's internal timer/counter. I'd use two IOs (one for each sensor), and set up an interrupt on each line. The first interrupt would clear and start a timer, and the second interrupt would stop the timer, do the calculation, and send it to the display.
So I'd suggest reading some about interrupts and timer/counter use in your uP as a place to start.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
