Calorimetry - Calculating absorbed and released heat
  • Thread starter Thread starter edimeo25
    Calorimetry Heat
The discussion focuses on calculating the heat absorbed by water in a calorimeter and the heat released by burning ethanol. The experiment involved burning 20g of ethanol to heat 280g of water, resulting in a temperature change of 30°C. The calculations yielded a heat absorption of 35.1 kJ for the water and a corresponding heat release of -35.1 kJ for the ethanol. The molar heat of combustion for ethanol was determined to be 81.08 kJ/mol.
  • Understanding of calorimetry principles
  • Knowledge of specific heat capacity calculations
  • Familiarity with enthalpy and heat transfer concepts
  • Basic chemistry knowledge regarding combustion reactions
  • Study the principles of calorimetry in detail
  • Learn about specific heat capacity and its applications
  • Research the concept of enthalpy and its relation to heat (Q)
  • Explore combustion reactions and their thermodynamic properties
Chemistry students, educators, and anyone involved in thermodynamics or calorimetry experiments will benefit from this discussion.
edimeo25
Calculate the heat absorbed by the water in the calorimeter and the heat released by 1,0g of burning ethanol. Then, calculate the molar heat of combustion (kJ/mol) of the ethanol.
The calorimeter used was very makeshift: ethanol in an alcohol burner was lit under a can containing water, both of which were placed inside a hollowed out larger can.
Here is what is known:
mass of ethanol burned = 20g
mass of heated water = 280g
change in temperature = 30"degrees"C
Q(water) = -Q(ethanol)
mc"delta"T = - (mc"delta"T)
280g*4.184J/g"degree"C*30 = -Q(ethanol)
Q(water) = mc"delta"T = 280g*4.184J/g"degree"C*30"degrees"C = 35145.6J = 35.1kJ
Q(ethanol) = -Q(water) = -35.1kJ (for 20g)
Q(per gram of ethanol) = -35.1kJ / 20g = -1.755kJ/g = -1.76kJ/g
Q or "delta"H? (per mol of ethanol) = -1.76kJ/g * 46.07g/mol = 81.08kJ/mol
--> Does this make sense? Is it right? And what is the difference between Q and "delta"H?
Looks OK.
Check enthalpy definition. In some circumstances it is identical to Q, in some it is not.
  • · Replies 16 ·
  • · Replies 131 ·
11K
