Isentropic efficiency vs polytropic efficiency of a gas turbine
The discussion centers on the differences between isentropic efficiency and polytropic efficiency in gas turbines, exploring their definitions, practical implications, and applications in compressor design and testing. Participants seek clarification on how these efficiencies operate in real-world scenarios.
  • Homework-related
  • Some participants note that while definitions of isentropic and polytropic efficiencies are clear, their practical differences remain confusing.
  • One participant references a book stating that using polytropic efficiency simplifies algebra and removes bias when comparing machines with different pressure ratios.
  • Another participant describes the isentropic process as one where entropy remains constant, implying energy conservation in axial-flow turbines, while noting that jet engine systems are not entirely ideal.
  • Discussion includes the observation that compressor stages do not follow an adiabatic process due to heat transfer from previously compressed air.
  • A participant asks for a brief explanation of compressor design and how to determine polytropic and isentropic efficiencies during testing, including the variation of parameters like pressure ratio and mass flow.
  • One participant suggests purchasing various texts for deeper understanding of jet engine design and operation.
  • Another participant inquires about increasing mass flow rate at altitude and whether this is achieved solely by increasing engine RPM.
  • A response indicates that increasing mass flow rate involves advancing throttles, which adds fuel and energy to the system, but also notes the limitations due to engine efficiency and stall risks.
Participants express confusion over the practical differences between isentropic and polytropic efficiencies, indicating that multiple competing views and uncertainties remain regarding their applications and implications in gas turbine systems.
Participants mention various assumptions about the ideal behavior of thermodynamic processes and the complexities involved in real-world applications, such as heat transfer and efficiency optimization at different operating conditions.
jason.bourne
definition wise i got the difference between these two efficiencies.
but in practice how does these two differ?
i was referring to this book:
Jet propulsion: a simple guide to the aerodynamics and thermodynamic design ... By N. A. Cumpsty
he has mentioned this:
"using polytropic efficiency makes algebra easier, but it also removes a bias in the isentropic efficiency when comparing machines of different pressure ratios"
can anyone please explain me in a much better way how these two efficiencies work in real practice and how they are different coz still m totally confused?
When you look at a turbine's http://en.wikipedia.org/wiki/Compressor_map" , you'll notice it's depicted in terms of various throttle settings ranging from ground idle to climb, and with mass flow rate depicted along the x-axis while the pressure ratio is depicted along the y-axis.
In the upper-right of the graphic, you'll notice a subplot labeled "isentropic efficiency."
I take it you've heard of http://www.wikipedia.org" ...
The http://en.wikipedia.org/wiki/Isentropic_process" is one in which the entropy of the system remains constant. For axial-flow turbines, this means the engine system is neither gaining nor loosing energy, and whereby the sum total energies of all inputs equals that of the outputs. It also requires the energy to be at a constant rpm.
Since jet engines are designed primarily to operate at their greatest efficiencies at cruise altitude, it's appropriate to begin with isentropic maps and work from there.
The http://en.wikipedia.org/wiki/Polytropic_process" is used for systems which obey the ideal gas law. While it applies to all ideal thermodynamic cycles, including the famous Carnot cycle, jet engine thermodynamic systems are not quite "ideal."
The compressor stages do not follow the adiabatic process, either, as successive compressor stages are warmer due to previously compressed air, and they've passed some of that heat to the vanes, which further heat incoming air. So it's not truly adiabatic, which requires that no heat is transferred to/from the working fluid. Clearly, the combustion stage is not adiabatic.
thanks mugaliens for the reply.
i don't have a textbook in which i could find out how things work at the design stage.
can you briefly explain me how a compressor is designed?
and suppose if we are at a compressor test facility, with a compressor mounted on a test rig.
so if we want to determine these efficiencies (polytropic and isentropic), how do we do that?
like how the parameters (like pressure ratio, mass flow, temperature ratio etc) are varied and stuff?
If you have $25 to spare, buy https://www.amazon.com/dp/1853108340/?tag=pfamazon01-20: Fundamentals of Theory, Design and Operation.
It's 236 pages will cover the design basics. More advanced texts begin around $100, and your local university aerospace professor should be able to guide you in the right direction.
If you want a basic non-technical approach, https://www.amazon.com/dp/1852606185/?tag=pfamazon01-20.
If you want a more detailed, and military, but still conceptual approach, https://www.amazon.com/dp/1423552660/?tag=pfamazon01-20.
* If you want a fairly realistic, 500+ page hands-on approach to designing a jet engine from RFP to delivery, https://www.amazon.com/dp/1563475383/?tag=pfamazon01-20.
** If you want an aerospace engineering text on the mechanics and thermodynamics of propulsion (both jets and rockets), https://www.amazon.com/dp/0201146592/?tag=pfamazon01-20.
all right. i'll buy one.
hey but i have this one thing to ask:
like in flight condition, at some altitude, suppose if we want to increase the mass flow rate of air, what do we do? like on what parameters does it depend on?
is it done only by increasing the engine RPM?
Engines are optimized for efficiency at cruise altitude, with a little extra oomph built in for climb to that altitude. It's that extra oomph which pilots use to go faster than planned, but doing so uses more fuel, so the only time they're authorized to do so is if passengers missing connecting flights would prove more expensive to the airlines than the cost of the extra fuel used.
To increase the mass flow rate, simply advance the throttles. This introduces more fuel, which adds more energy to the system, resulting in greater rpm, and greater thrust.
As I said, however, there's a limit, as engines are bordering on stall for max efficiency, anyway, so there's not a lot of room for additional thrust.
okay. i got it.
thanks mugaliens
12K
23K
