Calculating Acceleration: Newton's Laws Homework Help"
  • Thread starter Thread starter black_hole
    Laws Newton's laws
The discussion revolves around applying Newton's laws to two different scenarios: a person standing on a scale in a moving elevator and a mass subjected to two horizontal forces. Participants are exploring the implications of constant velocity and the calculation of acceleration from forces.
  • Mixed
  • Participants are attempting to understand the relationship between constant velocity and acceleration in the elevator scenario, questioning whether the acceleration is indeed zero. In the second scenario, there is uncertainty about how to approach the problem of calculating acceleration from two perpendicular forces.
Some participants have provided insights regarding the net forces acting on the person in the elevator, suggesting that if there is no acceleration, the forces balance. Others have introduced vector concepts for the second problem, indicating a potential direction for resolving the issue of calculating the resultant force and acceleration.
Participants note the use of decimals in the problem statements and question whether vector concepts have been covered in their studies, indicating a possible gap in knowledge that could affect their understanding of the second problem.
black_hole
A person stands on a scale on an elevator. If the mass of the person is 96.34 kg and the elevator travels upward at a constant speed of 4.42 m/s, what is the reading on the scale?
m = 96.34 kg
V avg = 4.42 m/s
I think what this is asking for is the weight of the person, the force exerted on the scale by the person. So if the velocity is constant, wouldn't the acceleration be 0? So F = ma = 0. I don't know if that's right?
Two horizontal forces act on a 1.7 kg mass. One force has a magnitude of 9.78 N and is directed due north. The second force toward the east has a magnitude of 1.48 N. What is the magnitude of the acceleration of the mass?
I don't know how to go about solving this.
m = 96.34 kg
V avg = 4.42 m/s
Wow your teacher likes decimals.
If the person on the elevator is not accelerating then there is no net force as you sort of stated. If this is true, the persons weight, ma, or mg, is equal to the push up from the floor of the elevator, or the scale if the person is standing on a scale on the elevator.
For the second problem, have you used vectors yet?
1) a) realize that if the velocity of the elevator is constant ,then you know from Newton's first law that the net force acting on the elevator is zero. If this net force is zero then the normal force exerted upward on you by the scale is _________ to the downward force you exert on the scale. The solution follows from there.
2) initially, mass m is at rest so the net force acting on it is zero. since the two forces acting on the mass are perpendicular and since they are both positive, use dot(scalar) product to find the sum of these two vectors. the resultant vector gives the magnitude and direction of the net force acting on the mass m. To find m's acceleration just use magnitude of the aforementioned resultant vector and Newton's second law .
Hi black_hole,
For the second question, just in case you haven't come across vectors yet, you can find the resultant force on the mass using Pythagoras Theorem. To find the acceleration just divide this resultant force by the mass (Newton's Second Law).
Cheers.
  • · Replies 42 ·
