Help deriving integer sequence formula
The discussion focuses on deriving an integer sequence formula related to the maximum number of partitions with specific properties, including equal minimum and maximum values, equal member counts, and equal sums. The user provided an example with minimum value 1, maximum value 6, count 4, and sum 14, resulting in two valid partitions: {1,3,4,6} and {1,2,5,6}. A brute force algorithm was used to generate maximums for widths up to 24, but it failed at width 25 due to excessive memory requirements. The user suggests a potential relationship between the derived sequence and the Fibonacci and Lucas series, and seeks assistance in identifying a formula using Mathematica 7.
  • Understanding of integer partitions
  • Familiarity with brute force algorithms
  • Knowledge of Fibonacci and Lucas series
  • Experience with Mathematica 7 for sequence analysis
  • Research integer partition theory and its applications
  • Learn about optimizing brute force algorithms for combinatorial problems
  • Study the mathematical properties of Fibonacci and Lucas series
  • Explore Mathematica 7's capabilities for sequence calculations and pattern recognition
Mathematicians, computer scientists, and anyone interested in combinatorial mathematics or algorithm optimization will benefit from this discussion.
ktoz
Hi
I'm playing around with partitions and have come up with an integer sequence representing the maximum number of partitions of various "widths" that display the following properties:
- min values in partition are equal
- max values in partition are equal
- partitions contain equal number of members
- sum of members is equal
For example, given:
min = 1
max = 6
count = 4
sum = 14
There are only two partitions that satisfy the constraints
{1,3,4,6}
{1,2,5,6}
Using a brute force algorithm, I came up with the following maximums for width = {1, 2, 3, 4 ..., 24}
1, 1, 1, 1, 1, 2, 2, 3, 5, 8, 12, 20, 32, 58, 94, 169, 289, 526, 910, 1667, 2934, 5448, 9686, 18084
My algorithm breaks at 25 due to the huge memory trequirements needed to sample every possible combination. I plugged it into http://www.research.att.com/~njas/sequences/" , but no luck.
With a little tweaking, the series seems like it might have some sort of partial relationship with the Fibonacci and Lucas series, but I haven't been able to come up with anything concrete.
Code:
 ,  ,  ,  ,  ,  , 1, 2, 3, 5, 8,  13, 21, 34, 55,  89, 144, 233, 377 	(fib)
		  1, 1, 2, 3, 4,  7,  11, 24, 39,  86, 145, 293, 533	(partial lucas)
Anyone see the pattern? Or perhaps someone with Mathematica 7 could plug the series into the series calculator and come up with the formula?
Thanks for any help
ktoz said:
Hi
For example, given:
min = 1
max = 6
count = 4
sum = 14
{1,3,4,6}
{1,2,5,6}
Code:
Thanks for any help
Could you define "width"? You give 4 variables for widths but you give a sequence for widths = [1,2,3,...} so I don't understand what you mean.
  • · Replies 17 ·
  • · Replies 17 ·
