Density equation of sound wave
The discussion focuses on deriving the density equation of a sound wave from the pressure equation given as ΔP = Po cos(ωt - kx). The user presents several equations, including the relationship between bulk modulus (B), pressure change (ΔP), and volume change (ΔV/V). The derivation leads to the expression for the change in density (∂ρ) in terms of the pressure and bulk modulus. The final equation presented is ∂ρ = (ρ Po/B) cos(ωt - kx), which seeks validation for its correctness. The conversation emphasizes the need for proof and proper explanation in the derivation process.
abhineetK
Let pressure equation of sound wave be
\Deltap=Pocos(\omegat-kx), then
what will be the density equation of the sound wave?
give your answer with proof and proper explanation...(Derive the equation)
Hi abhineetK! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
\deltaP=Pocos(\omegat-kx) ...(1)
B=-\deltaP/(\DeltaV/V) ...(2)
\rho=m/V
=>\partial\rho=-(m/V2)\partialV
=>\partial\rho=-\rho(\partialV/V)
=>\partial\rho/\rho=-\partialV/V
=>\partial\rho/\rho=\deltaP/B [using (2)]
=>\partial\rho=(\rho.Po/B)cos(\omegat-kx) [using (1)]
Is it correct?
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
