Solving the 411nm Wavelength Emission from Hydrogen
The discussion revolves around identifying the transition responsible for the 411 nm wavelength emission from hydrogen. The relevant formula, R = (1/n^2 - 1/k^2), is used to calculate the wavelength based on different energy level transitions. Participants express uncertainty about the correct options, eliminating choices a, b, and e, and focusing on c and d. A suggestion is made to plug in the values for k and n from the remaining options into the formula to determine which produces the correct wavelength. The conversation emphasizes the need for clarity in applying the Rydberg formula to solve the problem.
adream
Light of wavelength 411 nm is emitted from a hydrogen discharge. What transition produces this emission?
a. k = 5 to n =1
b. k = 4.5 to n = 2
c. k = 2 to n = 6
d. k = 2 to n = 3
e. k = 6 to n = 2
R = (1/n^2 - 1/k^2)
I'm not really sure how to solve it. But I'm sure its not a, b, or e. Because n to be bigger then k to make it positive. THat left me with c and d. Someone please hint me how to do this.
Just plug in the choices for k and n pairs in the formula and see which one gives you the right wavelength.
totally confused. >< can someone explain it to me.
